brewera
- Feb 15, 2022
- 3
I have a small van that I installed a single 116Ah Firefly G31 battery ([https://fireflyenergy.com/oasis-mcf-g31.html](https://fireflyenergy.com/oasis-mcf-g31.html)) in for my camping adventures. I charge the battery with a Kisae DMT1250 MPPT charger ( [DMT1250 – Kisae Technology Inc (kisaepower.com)](https://www.kisaepower.com/products/dmt1250/) ) via DC to DC or the single 100 watt solar panel on the roof. I currently do not have any method to shore charge. It has been working great for about seven months and now lately I am not getting as long of run times for my minimal usage. I then found in the Firefly manual that I should occasionally perform a "restoration charge" on the battery. The procedure they state is:
As stated, Firefly Batteries can operate in a partial state of charge for long periods of time without sustaining any permanent damage. The usable capacity will decrease, however, with each cycle within a partial state of charge, up to a point. In order to regain the full original capacity and in some cases more, it is necessary to perform a restoration charge. To perform the restoration charge: charge the G31 to 14.4V and continue to charge until the current drops to 0.5 A on the G31 and apply a float charge of 13.5V for 24 hours. Fully discharge the battery to 10.5V, and then repeat the same charge cycle.
What would you all recommend would be the best way to accomplish this procedure? I own a couple of multimeters. Do I need to buy special equipment? Do I need to take the battery out of the van? I am looking for some creative solutions.
