Does anybody have a recommendation for breaker filler covers (not the wire knockouts) for the Midnite Big Baby breaker box?
I initially had two MNEAC breakers mounted on the left side. However, I need them mounted dead center, to provide enough space on the DIN rail to mount two terminal blocks on each side of the breakers. The terminal blocks do not stick out of the box. If I mount the breakers to the left side, there is some wasted space on the left side of the DIN rail as it can't even hold one terminal block that way. Hence the need for dead center.
I would need two fillers. The MNEAC breakers are 13mm wide and 57mm high where they stick out of the box
If I have to shave something, that's fine.
Thanks
Thanks
