Steve_S
Offgrid Cabineer, N.E. Ontario, Canada
Good Day everyone,
I'm in process of investigating options to replace my FLA Batteries with Lithium. Something I have to do fairly quickly so "the heat is on" you might say. I'm fielding a couple of options at the moment and this brings the question. Does anyone have experience with "Chargery Power" brand BMS ?
REF:
direct: http://chargery.com/BMS8T.asp or
I have an opportunity buy 12, Chevy Volt 6S Modules which I can config @ 24VDC fort something around 13kwh or so. This is the BMS suggested by the vendor but I would like to know more.... Is there something better / more flexible at similar price point or any "gotcha's" lurking, waiting to pounce ? There is also the possibility that the battery pack could get expanded later so I don't really want to get locked into a BMS that would limit such.
Ideally, I would love to have a BMS which I can use Modbus or ? to communicate & interact with it using a RaspberryPi, node-red.
What's worse, deciding on battery options !
1) 12, Volt 6S modules (24vdc 13kwh +/-) [$3600 CAD] or
2) 2 Tesla Model S Packs for (24vdc 11kwh +/-) [ $3300 CAD] or
3) New LifePO4 either 16pcs @ 200AH or 8pcs @ 400Ah for 24V 400Ah / ~10kwh [varies but close to above #s]
Geez, makes my Brain Hurt ! and terrifies the wallet !
Thanks in Advance for any help
Steve
REF:
Chargery BMS and Charger - Shop Cheap Chargery BMS and Charger from China Chargery BMS and Charger Suppliers at IC GOGOGO Store on Aliexpress.com
Shopping for Cheap Chargery BMS and Charger at IC GOGOGO Store and more from lipo life,life smart,lipo display on Aliexpress.com ,the Leading Trading Marketplace from China
www.aliexpress.com
Steve
