Project eYacht
After some help controlling my DEYE with MODBUS. I have a 30kW hybrid DEYE inverter in our solar electric boat. I have solar connected via PV (DC solar) and GEN (AC solar) ports as well as shorepower on the GRID input. Problem is I also have 250 kW DC generation capability from my electric motors that goes direct to the BMS, bypassing the DEYE. When generating via the electric motors I want to be able to disable all the other inputs for charging from the DEYE. Is there a way to do this via MODBUS? I am currently thinking of using registers 231 and 232 for enable/disable GEN and GRID inputs, but I cant find anywhere to block the PV power. Is there a simpler way - can I just limit the power the DEYE is allowed to output to the battery to zero instead?
