Saturn_up
Full Time Off Grid
- Jan 3, 2022
- 12
So no question on this thread. Just putting this out there to be accessible to other people who have gone round and round trying to get the v2 batteries to communicate with your cc/inverter.
My setup
Growatt spf 6000 t dvm mpv
(2) Eg4 ll v2 51.2v
panels- irrelevant
So looong story short. Dip switches are upside down, and the sequencing is wrong.
Wiring.
Top battery-comm port to Top battery-comm port.
Either Battery's Rs485 port to inverter bms port (not rs485)
1. set both batteries to 16 (all switches towards face plate / towards you)
2. Turn batteries off with push button, dont worry about the breakers, didnt matter.
3. Turn batteries on.
4. Hold middle right button for 5 seconds and release.
5. Set protocol to rs485 for growatt
6. Back out of menu to the main screen.
7. Power off both batteries (button only)
8. Set both batteries to id 1 (switch closest to comm port down, all others up)
9. Power batteries on.
Inverter setting (05) LI
Inverter setting (51) L01
It works. No promises.
The dip switches are visually in position 8 The reason i set them to (8) is because that would be 1 if the switch was the right way up.
I tried setting them to 1 and 2 but the inverter only showed half soc. When both set to 1 it shows the same soc as the battery display.
I really hope this helps someone. God knows ive spent days standing out in the cold trying everything i could think of.
My setup
(2) Eg4 ll v2 51.2v
panels- irrelevant
Wiring.
