@v_green57 I see that you have some Epevers as well , can you pls list which value you see in D1 on 3201 register during no-charge,float, boost? Thank you
This is what it is right now, dark, no sun:
pi@zero2w1:~ $ epevermodbus --portname /dev/ttyUSB0 --slaveaddress 1
Real Time Data
Solar voltage: 6.75V
Solar current: 0A
Solar power: 0.0W
Load voltage: 12.16V
Load current: 0A
Load power: 0.0W
Battery voltage: 12.16V
Battery current: 0.0A
Battery power: 0.0W
Battery state of charge: 38%
Battery temperature: 20.64°C
Remote battery temperature: 0°C
Controller temperature: 17.32°C
Battery status: {'wrong_identifaction_for_rated_voltage': False, 'battery_inner_resistence_abnormal': False, 'temperature_warning_status': 'NORMAL', 'battery_status': 'NORMAL'}
Charging equipment status: {'input_voltage_status': 'NORMAL', 'charging_mosfet_is_short_circuit': False, 'charging_or_anti_reverse_mosfet_is_open_circuit': False, 'anti_reverse_mosfet_is_short_circuit': False, 'input_over_current': False, 'load_over_current': False, 'load_short_circuit': False, 'load_mosfet_short_circuit': False, 'disequilibrium_in_three_circuits': False, 'pv_input_short_circuit': False, 'charging_status': 'NO_CHARGING', 'fault': False, 'running': True}
Discharging equipment status: {'input_voltage_status': 'NORMAL', 'output_power_load': 'LIGHT', 'short_circuit': False, 'unable_to_discharge': False, 'unable_to_stop_discharging': False, 'output_voltage_abnormal': False, 'input_over_voltage': False, 'short_circuit_in_high_voltage_side': False, 'boost_over_voltage': False, 'output_over_voltage': False, 'fault': False, 'running': True}
Day time: True
Night time: False
Maximum battery voltage today: 12.73V
Minimum battery voltage today: 11.49V
Device over temperature: False
I will leave it up to you to figure out which param is the bit you're interested in.
Other states when the sun is up, etc. will have to wait when I am able to read things at that point.
