Is this your freezer?
Looking at comparable models at HomeDepot, I'd guestimate your unit might consume between 1.6 and 1.8kWh of power per day. But, as E.Cho mentions, the best option is using the killawatt to actually determine your real-world consumption. But, we can start with the 1.8kWh value and work with that till you have better real-world numbers.
Let's assume you have to run this unit on standard 120V 60Hz AC. The inverter just being on, whether or not the freezer is actually running, will also consume power. That varies from inverter to inverter, but let's say it's 1000Wh per day. So, to keep the freezer on 24/7 you need 1.8kWh + 1.0kWh = 2.8kWh of power. Let's round that to 3.0.
1000W at startup is a bit large for a 1000W inverter, so you want to look at one that can handle 2000W. You really never want to run your equipment at the ragged upper edge of their specifications.
You're in Texas, so you're in a solar-rich area. Let's assume you get about 6 sunhours (sh) per day in June and 3 sh in December. Go with the lowest number, never the highest. Assuming you need 3000Wh of power each and every day, and you get 3 sunhours of solar in December, you need 3000Wh/3 sh =1000W of panels. At 12V, that would be a substantial number of amps, so you are better off with a 24V system, that is a 24V battery bank, powering a 24V inverter.
Assuming at startup you are consuming 1000W, from a 24V battery bank that would be ~ 42Amps. Look at getting 400Ah lead-acid batteries, or maybe 200Ah of Li batteries to support that level of battery drain.
Keep in mind that these are numbers that I came up with, not YOUR numbers. I suspect that this is a commercial-grade unit that consumes more than a domestic HomeDepot model, so plan on these numbers as the bare minimum of what will be needed.
So, minimally, you'll need....
1000W of panels, say four 250W residential panels
40+amp charge controller
2000W 24V sine-wave inverter
200-400Ah
200-400Ah batteries
ideally how many would I need to run for 24hrs? Please
