I'm the freeze protection for my batteries. During your winter time, will the battery be used of just sitting there waiting for warmer weather? If its just sitting in the cold all you need is a disconnect. My batteries have a low temp cut off but I don't rely on it. I have bluetooth and can see the temperature of the battery and can shut them down if I choose. Watching mine, their thermal mass keeps them in the safe zone during night time dips in temperature. I have a 100Ah that sits on the tongue that I bring in the house during the cold because it is a stupid battery and doesn't know how to save itself.
Keep in mind that freeze protection saves the battery when the temperature drops but if it keeps getting colder (say -10F) you need to take measures to warm them up. Freeze protection doesn't mean that they have heaters built in, just a cut off switch to stop current. Batteries with built in heaters need a charging source to keep them going.
If one can insulate the battery area good then it’s all easy and cheap to solve…
if one can’t easily insulate then I would buy good heated batteries And move on with life
Depending on your install, location and temps if one can insulate ,leave the inverter on and put a 25 or 30 watt incandescent light bulb in the batt area , position the batts about 3/4 inch off of the bottom or floor surface to allow air circulation Under them ,( I use 3/4 inch plywood strips) .. Add a small 12v or 120v fan ..( about 5 to 10 watts ).
Now find somthing you need to run anyway ( somewhere) and turn it on ….run it …off the batts
the more you power some device the more the batts will produce heat. If you don’t need anything running then idle load from the inverter + powering the light bulb and the fan off the batts will create collective warmth.
The fan will circulate the warm air around .
if your using Victron gear hook the inverter BT dongle with temp sensor in the area your monitoring to report to your phone app over the connect network ..not on the battery but in the central area of FREE AIR ……whatever the free air area temp IS , is a good reference to the battery temps…
now test the system with the BT sensor and verify with a lazar temp pointer and track internal temps compared to outside temp… test every scenario you might face ..
soon it will be clear what level of protection you have and how much power is needed to heat the batts . There will be a learning curve to nail down…it become easy to know what you will need after a short while.
the next day the sun will hit your panels and replace the few hundred watts you used overnight…
It just keeps everything warm and happy Day after day after day…
I have been trying and testing this out over the last 2 winters … works great at least down to zero F …all winter…below that point I may add a 25 watt light bulb for good back up and it is fine… way below zero…
as back up if somthing fails , your batts BMS ( mine anyway) will shut down the batts from charging .
You should be aware of what your system is doing in all cases…you are the ultimate back up device…
if insulated well it’s amazing how little power you will need…this is easy as hell to do….
It will be about 15 F here tonite…everything is in place and using about 45 watts.( I don’t use a light bulb anymore) as my inverter and SCC is inside the batt area.. it will stay 50 - 55 inside the batt compartment day and night..
the real key here is insulation… after that ,there has to be 10 ways to fabricate what you need.
good luck…J.
