Brae09
- Feb 5, 2020
- 24
I recently built an automatic duck coop door. The power for the actuator is from a 12 volt 7 amp battery which is charged by a small 3 watt solar panel. There is a pwm charge controller that both the battery and the panel are connected to. But the door operation keeps failing. Each time I found the battery in very low voltage, around 10 volt. The battery is new. The panel outputs 17 volt during the day. I wondered if the battery was being drained at night when the panel was not putting out a charge. So I did this test. With the battery connected to the controller and the solar panel disconnected, I measured the voltage on the terminals where the panel was connected to. It was 2 volt. Does this mean that the controller would be leaking power if the panel is connected but is not putting out a charge like at night? I would think there should be no voltage on those terminals if the controller is working properly. I would appreciate your thoughts on this.
