My current issues with these units (I have not been able to get any response from the retailer over the past month either by phone, email or web form)
1. One unit loses settings after reset
* Have to change it back from single to 2P1 each time
* is there a way to reset the unit from a fault state without cuttings solar and grid power to it?
2. Unit faults with F80, power gets cut
* unclear if this happens only when solar is connected to 2P1 unit
3. F52 error, power gets cut
* This has happened multiple times when moving from SUB to SBU, I'm not sure that's the only time it happens
4. Long switching time > specifications
* when switching to battery there is a long enough delay to see the power drop and come back which causes some devices to lose their settings, and I expect is not particularly healthy for anything hooked up
5. Unexplained switch to bypass vs battery
* some times (usually at about half load [3-4kW]) the units will switch to what appears to be bypass but still feeding power from the batteries
* when in this state it does not report the current draw from the batteries
