Looking for advice regarding multiple voltages, AC, and DC chassis grounding on my 5th Wheel RV. Like most I guess, my RV factory 12 volt system is grounded to the RV chassis - the battery negative is connected to the RV chassis. I also have a 240v minisplit and a 4-1 PV combiner with surge arrestor...both which recommend grounding to the chassis. I also have the EG4 6000EX 240v inverter. The PV surge arrestor leaks some minimal DC current in normal operation as I understand by design - the case gives a little tingle shock. I am wondering what is the effect if the 12 volt DC negative is connected to the chassis and also the surge arrestor. For some reason this does not sound like a good idea to me. Next then, the minisplit is mounted to the chassis also so, as a side effect, the chassis DC negative current will be present on the minisplit case. Now then comes the AC green earth ground...but I have no ground rod in my off-grid RV. Should it also be connected to the chassis frame? Then also, assuming the inverter bonds ground and neutral when unplugged from shore power...there is always some unbalanced AC spilling over to the 120v neutral and thus the bonded earth ground. This all seems like a meltdown in the making to me. What is the safe approach to this problem?
