When I checked on my system this morning, my multiplus was OFF and the low battery light was flashing
I have recently added solar and have been testing it out over the past 8-10 days. Settings I used in the charger are the same as in the MPII as per posts I’ve read.
With not much sun lately I’ve been running my batteries down by methodically adding loads to test and wanting to trigger my “ignore AC input” assistant which is set to 15% and charge till 30%.
I’m confident that the system shut down because of the DC low shutdown @ 48v, restart @49v.
I can easily set my "ignore AC" assistant to turn on at 16-17% if that’s what would be recommended but as I dug a bit deeper I realized that while my SOC slowly declined at a predictable rate over the last week, my voltage took a nosedive overnight and I’m not sure what this could be an indicator of.
I’ve removed my critical loads and have kept fridge and freezer connected to try and see a pattern and it seems obvious that without sun the MPII will simply just continually turn its DC relays off and on at 48 and 49v respectively. I’ve now removed all loads to replenish the battery slowly. I’m thinking I should use the other relay to allow me to manually NOT ignore the ac input general flag
My battery screen shows 15% SOC at or around 48-48.3v when it’s telling the MPII to cut-out.
Is the voltage drop in my batteries normal or signalling something I should investigate? see below
Should I modify the low DC setting or have the ignore AC come in sooner?
Thanks to all of you for getting me this far along.
LAST 7 DAYS ( aside from a few solar days, steady decline in SOC )
LAST 24 Hrs ( steep voltage drop around 5-6am but steady SOC decline )
