I have had a T1N sprinter for a few years now. It has had various mechanical issues since I took ownership of it. Great performance and economy, interrupted by months of poor running, and random mechanical issues. Fuel leaks, water leaks, power loss, smoke... ugh.
But I tinker, and spend $ at shops... I have finally gotten the truck in good shape.
All that is up on the 9 foot roof is a pop up vent. I got up there on a ladder and measured the curve and width x length with solar panel ideas...
To place flat panels on it, I would need to build a steel platform, and it would raise the height considerably... most drive through height limits are 9foot or lower... the pop up vent is 9’3”... but I can swing wide and make that work usually... a platform, with strength to support glass panels, would add 6” at the center, and square the top a lot...
I am thinking a thin curved steel flat sheet could be set to the curve of the roof, and secured, then adhesive mount flex panels across the entire surface. It should keep the vehicle aerodynamics, and be nearly invisible from the ground... I know flex panels are short lived, but I drive A LOT. And economy is important. My fuel bill is around 1800 a month usually with my trucks... the sprinter cuts that in half...
The solar would be to maintain my 180Ah bank for jobsite power. Messy gas cans and generator noise is annoying..
I will post drawings and pics as I progress with the plan.
