Just curious if anyone else has encountered this issue with a new LiFePO4 battery seemingly dead and not charging. I went and got a multimeter and tested the battery and it's at 3.25V which seems crazy low. Almost wondering if that's "beyond repair damaged" low.
Here's some backstory for context:
Received the Li Time 230ah with BMS and Low Temp Protection. Initially tried charging it with 200w solar panel (probably needed more wattage since they said they send them mostly discharged for shipping reasons). I never tested the voltage when it arrived. Installed a new 60 am SCC that's connected to one 200w panel on my RV roof. Got everything hooked up and left it connected to shore power for 2 days. Disconnected shore power and the battery was dead. Figured my WFCO converter panel would charge the battery on shore power but it didn't.
Bought a Smart LiFePO4 25 amp battery charger to charge the battery. Hooked it up but the charger wouldn't charge the battery... it stayed in "Standby Mode". Thought maybe I had a faulty battery charger. Hooked it up to the car, and it worked no problem. So wondering if the BMS in my LiFePO4 has gone into "protection mode" and won't allow a charge?
Disconnected everything overnight. Li Time said you can reset the BMW by disconnecting everything for 30 min... that hasn't worked.
Thoughts and help appreciated.
