Gregorypscott
I started out watching every Solar guru on YouTube and of course it wasn’t long before I knew that Will Prowse was the guy to follow. Not that the others weren’t, but there is something about his style and charecter that make a person trust what he says and his enthusiasm to help others is off the chart.
My problem is that I have oversatuated my brain watching over 100 Will Prowse videos. He is a Genius and tries his best to explain things in laymen terms, but my mind is starting to feel like mash potatoes trying to figure out what’s best for me. So please don’t beat me up to bad with what seems to be simple to a lot of folks. I am not an electrician nor do I have much experiance outside of wiring 12g and 14g wire at home.
I want to put a system together Off-Grid to run sections of my home. My plan is to put a sub panel next to my home (grid) fuse panel (the sub panel is “stand alone” and not wired to the house breaker box). I’d like to slowly take the electrical wires from a 15-20 amp breaker from my homes breaker box and plug it into a 15-20 amp fuse in the Sub panel. Now the sub panel will be wired to an inverter with solar panels and LifePO4 24v or 48v batteries.
Since I want to start small and don’t want to get lost with all the parts involved in building a system from scratch that I’m thinking the EG4 6000 all in one should be the way to go.
I’m thinking I’d start out with maybe 6x 200w solar panels and 2x 200ah 48 volt LifeP04 batteries.
As time goes on, I’d like to slowly keep removing wires from my home fuse panel (Grid) and hook them to the sub panel. As I start using more power than the system allows, I’d add more batteries and Solar Panels.
Is this system (EG4 6000xp) a good starting all in one system to start with and expand as I can afford? Or am I going to regret this and wished I’d have bought something bigger like the Sol Ark 12k? I don’t believe I am going to try going completely off grid but I would like to eventually have all lights, electrical outlets including the refrigerator and 1 1/2 hp pool pump on solar someday.
I’d like to make sure I get a system that is certified just in case I decide to tie in with the grid later.
Any advice on a great system that I can start with under $6000 but can keep expanding.
