captainrivet
- Jan 27, 2020
- 73
Hi all,
I am planning to replace the small 12V AGM housebank with 2 Tesla modules and go 24V with the housebank.
The starter/bowtruster/windlass 12V batteries (2x140 AGM Fiam) will be kept completly seperatly, charged by the standard 60A/12V alternator and 2x75W solar panels to top up. A sterling 24V to 12V battery to battery charger is charging fallback in case 12V alternator and or solar fails.
Seeking for adivise/help regarding the setup of this modules tesla modules in a marine environment. Did I miss something,got something wrong....
Just find installations of this moduls in RV but didn't find a single one in a boat. So I take the two RV installation as base and work my way through to adapt to marine use.
frist one:
2nd Mortons on the moves setup
charger and inverter: Victron Quattro 24V/5000W/230 V with 120A/24V charge capabilities. The victron will take care about the specfic charge parameters Will suggests for the module on his page: https://www.mobile-solarpower.com/tesla-solar-battery-diy.html
I want to use 2 Tesla modules 5.3kw as my house bank which will never exceed 1C with 2 of them as a 5000W victron inverter is the biggest load. So in this case I don't need active cooling or heavy active cell balancing.
To marinize the modules I plan the following/What I figured so far:
1) To make them ready for marine environment you need to put the modules in an water tight box together with a BMS with low temp cutoff, so the agressive salt air is not penetrating into the battery.
2) even the victron Quattro takes care of the charge parameter for security reasons I want to add a smart BMS with low temp cut off to each module to manage the module: I plan to use one 320A 7s smart charger modules from Aliexpress (Will links the 100A smart modul from the same Aliexpress store) per modules
The smart BMS will also be configured with the parameter Will suggests for the Tesla.
3) A 200A fuse at each module to ensure you don't run it constant above 1C and get thermal problems due to missing cooling
4) each module seperatly with its own smart BMS and 200 A T-fuse is in a watertight box. That "tesla" box is then wrapped in a Fire-Resistent blanket for welding with the ends working as handles. Due to a fire brigade captain this gives me approx 3 min time to toss it overboard (just cut the two cables that comes out of the box and rip it out) when a thermal runaway in the tesla module occures and it catches fire.
That 3 min the module will need to burn through that blanket and gives me the thermal barrier to grab it and toss overboard. They tried that when they had to rescue someone out of a burning Tesla and it worked. Just as last borderline/plan D if everything else goes wrong.
All is overrated as marine environment is harsh and running everything far from the limit rises reliabilty and lifespan.
I will mount both modules easy accessible in the Pilot house in the well accessable lockers on top of the AGM batteries so I can really rip them out in worst case scenario.
What do you think so far about this approach?
frist one:
DIY Tesla Solar Battery
How to use a Tesla Model S for a DIY powerwall solar battery
15.98US $ |DYKB 7S 20S Smart Bluetooth 80A 100A 320A 300A 400A lithium Li Ion Lipo LiFePO4 Batterie BMS Schutz bord 48v 36v 24v 16S|Ersatzteile & Zubehör| - AliExpress
Smarter Shopping, Better Living! Aliexpress.com
de.aliexpress.com
Amazon.com: Tillman Heavy Duty Welding Blanket 6' x 6': Home Improvement
www.amazon.com
