So I’ve had my system for about 7 years now and today I heard a beeping sound going on and off two or three times and then everything connected to my solar system turned off. Initially I thought it was the 1000 psw inverter but then I noticed the fuse burnt out. In short, covered the panels and switches out the 100 Amp ANL fuse and put in 150 Amp ANL fuse. Not sure if I’m using the right fuses? Should I be using another kind of fuse?
After 7 years is there any kind of maintenance I should be doing?
