Redemption
- Sep 23, 2022
- 3
Hi All,
I am new to the forum and a novice. Five years ago, I installed a system in my parent's home. Since then, they have outgrown the system, and now I am considering an upgrade.
The current system consists of;
16 x 100 Watt Mono pannels
1 x Outback Flexmax 80 FM80 MPPT
1 x AIMS Power PICOGLF20W24V120VR
4 x 220 AH 6v batteries wired in Series for 24 volts.
They use the system daily. They have a Manual disconnect box to switch from grid to off-grid. I am considering purchasing an EG4-LifePower4 Lithium Battery, 48V. 100AH. That battery would be comparable to what they currently have with the added benefit of being able to draw them down to 20 percent as opposed to the 50 percent of the Lead-acid batteries they currently have. It would also mean less maintenance than the Lead Acid batteries.
I was told a few things yesterday that did not sound right, and I want to separate facts from fiction.
1- One 48v 100AH battery will be horrible; as they discharge, they will not be able to hold a load the same as having multiple batteries.
2- My 1600-watt solar panels will not be able to charge one 48v 100AH battery effectively. LIFEPO4 needs more panels than traditional LEAD acid batteries to achieve the same level of charging.
Currently, my parents do not use a lot of power. As I understand it, this is the math for their current system.
1600w x 4 hours of peak sun will give them up to 6400 watts every day on sunny days. "They probably generate more, but this formula I used to size their needs."
They have 24v x 200ah, giving them a total of 4800-watt hours. They can only use a max of 50% of that power, giving them 2400 watts to play with. During the day, the excess energy can be used to power most of their loads, consisting primarily of a tv, fan, and refrigerator. TV draws 70 watts, the fan draws 100 watts, and the fridge is pretty new and draws less than 100 watts. Fan TV is used sparingly in the evening and the fridge is on 24/7. Fidge consumes about 70 percent of the power, give or take 5 percent.
If I got them a 48v 100 AH battery, that would give them 5.12 KWH or 5400 watts. The battery would give them an extra day or two of energy on cloudy days. Drawing them down to 20 percent max would provide them with a total of 4320 watts, which is more than they currently use.
With all that In mind, here are my following few questions.
1- If I purchased Two G4 batteries, how many watts worth of panels should I shoot for to be able to charge the two banks in one typical day to 100%? Why two batteries? They recently purchased a mini-split AC unit. They do not use it on solar, but it would be nice if they could use it at least at night.
2- How many watts worth of panels to charge just one bank in one day to 100%?
For purposes of my use case, let's assume that I will Buy the all-in-one EG4 inverter/Charge controller unit. Also, the panels are located in Puerto Rico, with a fair bit of sun except on rainy days.
Thanks for the help in advance.
