Hi,
1. The solar charge controller is in VDC and the solar output power is in watt. so in case I have solar charger with min Solar Voltage of 120VDC how can I know the minimum watt the solar panel should generates? I want to buy 1 panel of 100W. the solar charger will operate?
2. what is the key difference between Micro-Inverter and DC power optimizer? in which circumstances I should prefer one instead the other? which is the most suitable for off-grid system?
3. what is buck-boost converter structure? what its advantages?
4. what is bypass diodes mechanism from Hot-Spot prevention?
Thanks
Thanks
