First, check your consumption. You'll shit yourself at the cost to power 44.1kWh/day - that's 1.5X the average U.S. household's energy consumption.
What does the yellow energy star label on them say?
For a
14.8cu-ft Frigidaire chest freezer at home depot:
296kWh/year
296kWh/year = 296/365 = 0.81kWh/day.
3X of that is 2.5kWh/day rounded up.
Note that this standard has changed to simply represent the amount of energy required to power it with the door closed in 90°F ambient conditions. If you open the door, or its hotter, you may use more. If it's colder, you'll use a lot less.
I have a 10.1 cu-ft fridge in a very cold RV right now, and it rarely runs. In the last 24 hours, it has turned on twice using about 60W of power:
For cool down or large mass changes, you can get extended run periods. I'd size for 3-4kWh/day
Second, model a 1kW array at your location on PV Watts in my signature line #1.
That will tell you the average solar hours/day you get by month.
Pick the most appropriate month (usually the lowest) and divide your consumption by that number, e.g., 4kWh/day / 2.5hr/day = 1600W of PV.
Re-run PVWatts for that array to see your actual harvest.
Check link #3 for a prediction on how many days your battery will be empty/full.
You'll need 3-4kWh of usable battery capacity for every 24 hours between charges.
