I just added a second bank of 6 Lifepower4 batteries, brining my total to 12.
I added a Victron Lynx as the bus bar.
Each set is in an EG4 cabinet.
Each set is wired to the Victron with + on top of cabinet bus and - on bottom.
I connected everything at 53% SOC.
I then ran AC charging and brought everything up to 100% SOC, at least according to the 18 kpv.
The lynx has 4 connection points, from left to right. I have the cables from the lynx going from the ends of the busbar to the 18.
I have cabinet 1 (old cabinet) into lynx spot 4, closest to end where cables go to the 18.
I have cabinet 2 into lynx spot 1, furthest from cables going to 18.
All cables are the same size.
18 and EG4 hub are showing 82% SOC. Weird thing is cabinet 1 batteries are around 86% and cabinet 2 batteries are below 80, with lowest around 76.
Why would those batteries drain down first?
I will charge up to 100% again tomorrow and check if there is still a spread.
