Crabby R
- Oct 7, 2019
- 7
Hi. I'm new but very interested in figuring this out. I have watched William Prowse's videos and I got inspired to make my own solar pontoon boat. I have a big flat roof on the boat that is perfect for solar panels so I put 8 of them up there. I have it all wired now but I have questions on setting the Solar Controller Parameters for deep cycle lead acid batteries. (I'm not going to buy lithium yet.) It's not in my budget. Maybe in 5 years.
So.....
Solar Controller Parameters for my electric solar pontoon boat project:
I have eight 100 watt solar panels on the roof. 4 panels wired in a series for a 48 volt system. The other 4 panels wired the same and then connected in parallel to the other 4.
I live in Central Florida so I have full sun most of the day (and the temperature can get as high as 95 degrees F for several months straight. (35 Celsius)
I have a 60 amp MPPT Solar Controller mounted in a waterproof box with a vent and a fan.
I have four 75 ah DEEP CYCLE flooded lead acid “Energizer” brand batteries wired in a series to be a 48 Volt. Since I am using Deep Cycle (not starting or combo marine batteries) does that mean I can discharge them to a lower voltage without damaging them? This is where I'm most confused.
I have an electric boat motor on order that is 48 volts and will draw a lot of amps. I will limit it at 60 amps because my goal is to troll with it at around 5-6 mph about once a week and have the solar panels recharge the batteries during the week. (I have everything wired with 6 gauge wire and a 70 amp breaker.) It would be great if I could get 3-5 years out of these batteries so I don’t want to damage them. I think I will only actually be running at 30-40 amps but I'm not sure yet.
Solar controller options that I need help with:
I set the controller as 48 volt 60 amp max.
So now I need to program the rest because I don’t trust the default settings.
Charge Voltage Settings:
Floating ____V
Equalizing ___V
Discharging Limit Vol. Set
Voltage Value ____V
Set Limit Value ____V
Low Voltage Protecton ___V
High Voltage Protection___V
There might also be some settings that ask for voltages under load. I’m not at the controller right now.
Any help is much appreciated!
I will post pictures when I get it operating.
Crabby R
So.....
Floating ____V
Equalizing ___V
Voltage Value ____V
Crabby R
