okay... so in the world of residential install, we all know the AFCI and RSD requirements. This is potentially the first off-grid string inverter compatible and UL listed solution. Does anyone know anything about it?
from Alte - "The OutBack Power FLEXware ICS Plus DC Combiner Box with PV Rapid Shutdown, AFCI, and disconnect is compatible with up to 6 PV Strings. It opens up controlled conductors within 10 feet of the PV array."
are panel-level modules required? how is RSD achieved?
Packages Available:
NOTE: All packages include (1) RSI, (1) BKR-CTRL-DC, (1) RTB device, and (1) or more FWPV6-FH600-SDA combiner boxes.
All packages are equipped with rapid shutdown, external disconnect, and PV AFCI functions.
ICSPLUS-1: Compatible with up to 6 strings of PV (one charge controller); includes (1) FWPV6-FH600-S
ICSPLUS-2: Compatible with up to 12 strings of PV (two charge controllers); includes (2) FWPV6-FH600-S
ICSPLUS-4: Compatible with up to 24 strings of PV (four charge controllers); includes (4) FWPV6-FH600-SDA
documentation
FLEXware ICS Plus - OutBack Power Inc
FLEXware ICS Plus is the first end-to-end solution listed to UL 1741 with photovoltaic rapid shutdown systems (PVRSS) for both battery-based and grid-direct solar systems.
www.outbackpower.com
Packages Available:
documentation
