Seems to me, to keep your GTI alive when the grid goes down, you need several things.
1. A relatively small Inverter with output protection against an in-fed voltage (if such a thing exists), a small battery to supply this Inverter, and a means of maintaining its charge.
2. Sufficient load to maintain the GTI output within the permissible voltage range programmed into the GTI. Ideally this would be in the form of a large battery, but arguably, the cheapest way to achieve it is by adding a big electric HWS tank with a wattage element approx. matched to the GTI max output.
3. Some form of controller to ensure that any power produced by the GTI goes into powering desired household needs, before being directed into the HWS.
4. A contactor to isolate the house from the grid.
If all this is even feasible, it's starting to sound far too complex, and ultimately, more complexity means more cost.
I have a far simpler solution, but not sure whether the necessary equipment even exists.
Install a Non GTI (I assume these operate as a voltage rather than current source), and a few contactors (incl. one to isolate the grid) to switch to an Off-grid configuration.
In my case, this would require a 5 kW Inverter capable of taking a 300VDC input (preferably dual MPPT). Is there such a beast, or any ideas as to alternatives? All I want is, if the grid goes down, the ability to use the power produced by my solar panels whilst the sun shines, without having to spend AU$14000+ to install a Powerwall plus controller.
