MrNatural22
?SW sunshine =⚡️⚡️lit up thru the darkness✌️
Never have had a reason to wake a sleeping 12v lifepo BMS but a distant neighbor ran his 100ah lifepo down to where the BMS did its job and shut down the battery. (32" TV and inverter on all night ) States he tried a lead acid 12v battery to wake up the the BMS but did nothing. \
no charger available. My thoughts are lifepo is 13.6v so one would need at least that or higher to wake the BMS which a LA battery can't supply.
I suggested using jumper cables from a running vehicle to quickly reawake the BMS. Good idea or bad idea?
Never had a reason to reawaken any of my batteries as i monitor them closely.
Any and all input on this is appreciated.
