N NorthShoreOahu New Member Joined Feb 24, 2024 Messages 13 Location Oahu Mar 20, 2024 #1 What's the recommended way to ground my solar arrays going into the eg4 6000xp?
T timselectric If I can do it, you can do it. Joined Feb 5, 2022 Messages 19,095 Mar 20, 2024 #2 NorthShoreOahu said: What's the recommended way to ground my solar arrays going into the eg4 6000xp? Click to expand... Connect the EGC from the array to the ground bar.
A AZ Solar Junkie Maricopa, AZ Joined Sep 26, 2023 Messages 513 Location Maricopa, AZ Mar 22, 2024 #4 There's another active thread where Jared from EG4 is discussing issues with grounding the array at the 6000XP PE bus. Might want to look into this a bit further. Here's a link to his initial comment but read the subsequent discussion as well. https://diysolarforum.com/threads/b...36x-280-watt-yingli-panels.80889/post-1042408
