bostonbuzz
- Jan 13, 2020
- 52
I'm planning a day/small cruising sailboat battery install with 2x 100ah 12v LIFEPO4 batteries. I believe that I don't need a lead-acid battery whatsoever since the LIFEPO4 can handle the cranking and it simplifies things. My issue is that if I use one battery for "house" and one for "starting" as is usual in boats so that you don't accidentally drain both while asleep or listening to the radio, what happens when I switch back to "ALL" on my marine battery switch? The batteries will be at a different SOC and then suddenly be connected in parallel. Is this bad?
Why wouldn't I just treat them as 1x 200ah 12v battery by wiring them in parallel before the switch? The only problem is I have to prevent the batteries from going below X% so that I can still start the engine - but I can just monitor them and I have a small generator on board - so no big problem there.
The other main disadvantage is if 1 battery goes bad, then I will have a little problem and potentially a dangerous one??? If I simply wire them in parallel, should I at least put a fuse on the positive between the two batteries or is this not needed since I'll have a 200A fuse on the main + anyway?
Thanks for the help.
Edit: not sure how my Victron 75/10 solar charger or ac chargers will be charging both batteries if they are not connected to one another in parallel either. Do I need two of each??
