Investigating methods to open a breaker remotely.
All the solar electronics are installed in a shed, 200 ft. behind the house.
There is 60A 2P Square D QO breaker in the shed that provides grid power to the
Schneider XW Pro inverters for "Grid Support".
I need to open this breaker from the house, to disconnect the grid from the inverters when big storms are in the area.
When the grid experiences an interruption from a lightning hit, the house heat pump being run by the inverters goes off line,
when the inverters switch over to battery.
(Guessing that the XW Pro contactor operation switching time is the cause.)
SWMBO is unhappy w/o air conditioning.
There is an Ethernet network in the house, connected to the shed Ethernet via fiber.
The Juniper Networks switch in the shed has POE available.
I want to replace the 60A QO breaker in the shed grid power panel w/ a Square D QOU 60A 2P shunt trip breaker.
Found some sources for relays w/ POE Ethernet connections / built in web server that would let me activate the relay / shunt trip over the network.
Example:
Any other ideas / suggestions would be great!
Example:
WebRelay™ | Single Relay & Input Module
WebRelay provides remote relay control and digital input monitoring over any IP network. It features a remote reboot mode for servers or IP cameras. WebRelay has a built-in web server which allows for control and monitoring of a device using a standard web browser. No programming required.
controlbyweb.com
