nickgosling
Hi, I am new here but having issues with my setup and my UK supplied is not being very helpful. Most days it operates perfectly. I have 2.4KW solar, the inverter and 10Kwh of PYTES batteries. The settings on the inverter are set to Solar only for charging and SOLAR/Battery/ Utility for output. At night I change these on the timer facility to charge the batteries and supply the house from Utility. This works well and then all of a sudden it wont charge correctly or change to the default settings.
Does anyone either have this problem or a solution for it. It is currently using a combination of UTILITY and SOLAR but not using the batteries despite the setting showing correctly as SOLAR/BATTERY/UTILITY.
It will revert to normal if i power down the unit and start again which is not the ideal solution.
Any help would be appreciated
