Michelle Konzack
Hello *,
I plan to build a 1000m3 pond which is feed trough a 140m long DN100 PP Pipe which I got for free.
They are 1,3m deep in the ground and will never see any frost.
However, parallel is a HDPE Pipe PN8 40x2,4 with 140m and I want to pump roughly 10m3/h with maximum 8 bar trough it.
Where the Pump is installed at the pond, I have no 230V available.
The Creek is starting above my EarthCellar with a waterfall and a little creek of 30m trough my Garden.
Where the pump is installed at the pond, I have only 24V DC available where 63A would be acceptable because there is a 4G50 where for PLUS and MINUS are used two conductors in parallel.
However, I have now several options where some are more or less not suitable because of the MTBF
Hence to increase the power stability without feeding back to my Victron BatteryProtect220 I would install a Diode/Rectifier with 200A and install at the end of the line a small 100Ah Acid Battery to stabilise the Voltage and use 1-2 Victron SmartSolar MPPT 250/100-Tr VE.Can with each 5 panels 550Wp
I tend to use option 3, because I can use a Curtis/Kelly Controller for the DC Motor and reduce the power/flowrate over night
What is your opinion?
Thanks for your Help
Michelle
- Using Solar Well Pumps from China
- Type: 2m3/h @120m head (80m head required because of the pressure loss in the HDPE pipe)
- Advantage: Can be used direcly from Solarpanels but also from Batteries
- Advantage: Easy to install and scale
- Advantage: Can NOT run 24/7
- Disadvantage: Lifespan not more then 2000hours
- 230V AC Pump
- Type: Hard to find
- Advantage: Compact and exist even as Slurry Pumps
- Advantage: Slury Pumps can run 24/7
- Disadvantage: Aquarium Pumps very expensive
- Disadvantage: Require Inverter which support 3kW hence a Victron MultiPlus 24/5000
- Motor coupled Pumps
- Type: Hard to find if not Marine version
- Advantage: Any Motors can be connected (I use IEC Norm Motors made in Germany from 550W to 5,5kW in 24V DC)
- Advantage: Can run 24/7
- Disadvantage: Hard to find
Michelle
