BarracudaBob
Harvesting free photons from clean fusion
When a switch opens DC it want to arc longer than a AC would. Mechanically they usually switch faster and contact travel farther away. Look what inverters are doing. They switch DC high current all the time. I can be done just don't use a AC device for DC. There are also ways to do it what a "snubber" capacitor to take the surge. For safety use a fuse and some sort of thermostat.Just asking…. Why if the power is no where near enough to overheat anything would one need a thermostat… let’s say you only wanted a moderate boost in temp ( for what ever reason ) ,,?
Why not just let the panel(s) just produce all they can and then let it cool a bit over night and start again the next day….
I have wondered this too but never dug in deep enough to find out the detail..
Experiment and find the amount of panels needed to reach a pre determined temp in perfect sun conditions with the right size heater element for the water volume and then let it roll …simple rig… maybe adjust the number of panel seasonally …
It’s Gona turn off anyway every afternoon… if it maxes out at ,(let’s say 130F,) why regulate it .. it’s nowhere near dangerous
I can think of a few uses for moderately hot water in a shop …
I’m sure I’m missing somthings, but what…!
J.
Here is another link to components: https://www.hurricanewindpower.com/dc-water-heating/
Amazon also sells DC water heater elements. I guess it is a thing.. I also watch a couple that use a solar dump voltage controled relay. When the batteries reach a certain voltage they dump the solar into the water heater. This way you can use the same panels for two different purposes.
