If you can get quality for that. And efficiency, i.e. W/m^2; newer panels are above 200 W/m^2, older about 2/3 of that.
Mounting hardware starts to dominate cost. The following link puts structural at $0.11/W
But none of those things explain the cyclical (and predictable) drop in fuel prices in the months leading up to a primary election, throughout the last 30 or more years. Can you point out what you're referring to, because I'm not seeing it: It is true, that there are dips in some election...
diysolarforum.com
You can get new panels with Stabuli MC4 around 370W in the $0.20/W range. A bunch of us bought pallets.
But if you are short on cash and can mount the $0.10 panels cheaply, that works for some. Forum members have bought "cracked backsheet" panels. Mostly working, couple of failures.
