Must I use "PV" wire for runs inside attic space?
inowhavesolar
I need to run wire from panels on roof, about 60ft, through attic space, to unfinished garage to inverter. There's an "attic tunnel" which connects main house to detached garage. Do I have to use #10 "PV wire" through the attic or can I transition in the roof box to standard #10 THHN wire?
I believe NEC code requires DC inside a dwelling to be contained in metal conduit or equivalent.
I can assure you from personal experience - if a wire can be accessed by a rodent - they will find it and chew through it.
No matter what anyone wants to believe, rodents can and do get literally anywhere and have a passion for chewing through wires.
They also love to chew on roofing materials including tar paper.
