House burned down
What type of shelves are these?
I worry about compressed cells on a shelf that sags in the middle, it squeezes the cells at the top like an accordion.
Was there ever a determination of the previous cell failure in the other post?
I've seen this effect with 100Ah cell stack. Compression was at least 2x on top with compressible foam sheets in between cells. Without compliant material between cells they must have been getting crushed at top corners. I also doubt that fuse started the fire. It could have blown as one cell stack developed internal short and sunk current via fuses from another battery stacks.
What voltage was that at and how does it compare to the class T. I only looked at the aic and time curves
I’ve never seen milliohm or wattage specified for Class T.
Looks like Eaton measures at the rated current and 0.7 rated current.
The class T fuse is rated at 300 amps but is connected to the positive post of the battery with 12” of 2 gauge welding cable and the fuse holder is screwed to a steel plate on the shelf.
@Brett V do you happen to have a photo of this? I was thinking with something similar off the positive post.
Went to the garage and got a few shots. Hope this answers your question.
@Brett V , Perfect. Thank you. I have a Lynx power-in converted to use 58v 125amp mega fuses for my 100ah batteries. Want to add a layer of additional protection like this.
Glad ya'll safe, but after seeing that leaky cell I'm thinking this is a runway grade B disaster, that liquid is highly flammable:
so if one of your cells puffed and spilled its goo, it would be an easy source for an ignition.
I still think the biggest unknown is WHY did the fuse blow in the first place? What failure started the whole thing? A leaky cell won't blow a fuse, just provide fuel.
So potentially lack of insulating material between/underneath cells caused friction during expansion/contraction and wore thru the thin film around the cell causing a short.
We may never know, but I see a lot of sloppy heat shrink on/under some of these lugs.
20200919_220538-jpg.23202
It seems odd to see the black insulated wires coming from the fuse block. One other oddity I notice is the large washer on the second to bottom left lug. Though the battery failing due to leakage causing a short seems a more likely possibility.
So sorry for the folks who lost their home. Are you a friend to have this much time to post? I can't imagine going online and posting after having lost my house.
I was under the impression they (LiFePO4) would not do this. Too bad.
No more than a leaking propane tank would.
LiFePO4 is different from chemistry in laptops, Chevy Bolt etc. in that it doesn't "Vent with Fire"; it vents below the auto-ignition temperature. A spark is needed to ignite it. The others, if they vent they are burning.
Unlike a propane tank, these might just release combustible liquid, not flammable gas. But if overheated, e.g. because damage causes internal short or there is an external short or over-charge, it heats up and gives off gas.
the 100 kwh lifepo4 battery caught fire at night and burned our house down. Luckily our family just made in out on time.
I am sorry for your loss. Just to clarify for other readers and emphasize what others have said, the cause of the fire was the arcing from the fuse not the LFP battery.
