I have pulled out the battery bank, and this one has cells arranged in a weird order also...A new version!
The latest one I opened up has a different failure, and a different control board...
This one has 3 red/black pairs of wires, one of which is soldered to the BMS...
And the cells are depleted to 5ish V... but the BMS has not failed I don’t think... I get readings on the P- terminal...
Nope, this one has a bad BMS also, but the fets are on the positive side instead of the negative side.
Ok, I am having trouble finding mounting screws that fit these...Here is the Two XT-60's I put on the casing. Yes there is the "cutout" for an XT-60 connector in the middle there but looking inside the case, the mainboard rests on the clip at that location and so I mounted them where I did. On my other unit I did the same thing but to the right of the original charging jack but that was a bad idea due to all the wires going up to the mainboard at that location.
Reason why I put two is because since I have multiple units, I can stack one on top of another and daisy chain each unit off of one line going to the solar panels.
Inside view. The wires coming from the input jack will need to be at a right angle. This is due to clearance. If I put them straight then it will be pressing against the battery/BMS. (Another lesson learned from my first iteration.)
Other end of the wires are soldered to the other end of the original solar input. I figure if it blows anything due to too high a current, it will probably blow a trace on the board instead of sending all the current to the mainboard/battery.
this is mostly a question new here..i have 5 with one that the bms is bad but the boards on ebay dont have the xtra 5 wire plug that goes to front panel..do all the functions still work..3s10p 26ah?? or is the old board still partially connected i dont have a schematicI have taken a few apart. The one that I feel has good upgradability is the Rockpals 300watt. The layout is pretty straightforward. Battery inside is pretty easy to change out/take apart. Battery is connected using a XT-60 inside. 3S10P. I have done some modding on mine where I made a XT-60 input connector on the housing.... Added another to where I am able to daisy change multiple units to charge. Connector to add external battery. All in all a great unit. I have mine running with AC inverter on 24 hours a day for the past year without it skipping a beat. The weak point on the unit is the BMS. The BMS that is soldered to the batteries seem to frequently go bad. I picked up six "for parts" unit on eBay and each one has the same BMS issue. BMS is cheap off eBay. I pick one up for $7 on ebay and everything works great again for each one. Battery's are all good on each one.
The original board is entirely removed.this is mostly a question new here..i have 5 with one that the bms is bad but the boards on ebay dont have the xtra 5 wire plug that goes to front panel..do all the functions still work..3s10p 26ah?? or is the old board still partially connected i dont have a schematic
