It doesn't claim to be constant current supply (that is a big deal, if this was CC the add would say so and they could charge more for it). Normal power supplies burp (turn the output off) if their current limit is exceeded and stay off until the load is disconnected. A battery charger power supply reduces the output voltage to maintain a constant current (that is why is is called a constant current supply).It has a constant current of 50 amps why cant it charge a battery? Even though I think the other is better. Just curious as to why the pointy heads say it wont work. Mine seems to work just fine.
If yours is working and it is not a constant current supply then your battery must not be pulling more than 50 A from it. Hook it up to a bigger, discharged battery and see what happens. A 50A CC supply will keep feeding the battery 50A until the battery is charged, a normal power supply will disconnect and refuse to charge the battery after a second or two.
Perhaps the seller doesn't know what they are selling. I doubt it though, CC power supplies cost more than normal power supplies.
