Bluemalibu
I need some help in deciding which SCC(s) would be best to utilize on a build.
I have two ground arrays... both utilizing 445W panels. ( Voc 49.9V, Vmp 41.2V, Isc 11.42A, Imp 10.82A )
The first array is comprised of 10 panels, and the problem that I have, is that I am limited to using an existing single pair of inground aluminum 1 AWG cables. ( 170 ft of small diameter conduit prohibits running additional lines)
The second array is likewise 170', but I can add additional wire runs to it as needed. It is a 16 panel array.
These will be feeding a 48V, 63.3kWh battery bank.
I currently have two unused Victron MPPT RS 450/100 SCC's and a new Schneider conext 600/100 SCC. Unfortunately, my solar OCD is kicking in, and these units aren't the best in low light situations, as they have respectively 120V and 190V minimums. This has me wondering if i should instead get the Outback FM100 with its 20V minimum.
Any help would be greatly appreciated...
What would you choose to use ????
