@SignatureSolarJames I've been thinking about this some more, would the attached picture show a better 5p configuration? I just don't know if the EG4 18kPV needs to be connected to a single battery pack or not; you mentioned needing bus bars, etc. for > 3p, so I assume no? Just trying to understand what you envisioned/recommend for a 5P configuration with a single 18kPV?
This layout could accommodate doubling the parallel kits between the batteries as well, would there be any benefit to that?
I'd like to use the pre-made parallel kit connections and leads and minimize the need for additional equipment/work/costs as much as possible; saving install effort, being plug and play, and the 10 year warranty makes an attractive bundle.
I'm currently planning my system and was going to build my batteries because the lifepro4 server rack batteries just weren't quite what I wanted; apparently I wasn't the only one thinking this because the powerpro announcement last week forced me back to the drawing board on my utility room layout, and has made the decision to build vs. buy much harder ?.
