TLDR the Tanuki's post: seal it up especially the bottom, stop transient air flow. that alone makes a huge difference. that fisher will heat that place much faster if you seal the house.
I have a large fisher wood stove next to the fireplace.
The chimney has 2 clay chimneys inside the brick. I had a fireplace insert I was going to install last year but the shear weight and having to modify the fireplace and install a liner stopped me from doing it. I think it would have been a good idea but wasn’t ready for the extra expense and effort last year. The large wood stove cranks some heat but the Swiss cheese cabin was releasing it quickly.
This winter I was considering replacing the 30,000 btu infrared heater with a blue flame thinking it might work better? Or running 2 of them? I have a 280gallon propane tank so I think I could run 2 easily to get the cabin warmer quicker. Does anyone know if the blue flame version would be worth buying and swapping? I have 2 infrared models I could currently install
that fisher is i think a "Momma Bear" model. single door front load, whats the width and height of it? I built my own "fisher stove" with some mods about 6 years ago. i added the internal baffle that was present on all later (1st gen EPA) fisher stoves, then i added in a second reburn section that works off of gasification. Either a momma bear or a poppa bear fisher will heat up that cabin no issues if you stop the air leaks. my bungalow/cabin on fuji I was running through about 9 cubic meters a year (2.5 cords) (early Nov. through april) weekends Fri night ~ Sun night / 60 days per year needing heat.
That was only after the 2nd year when i closed off the bottom of the cabin plus using very heavy drapes for all the windows to make a barrier. you could spot all of the air leaks in the winter by simply wetting your hand and walking around close to the windows and doors. prior to drapes and underpinning it was 1200 usd for heating oil and 2.5 cords of wood.
this year i had all new siding, with fiberglass bat insulation, double pane glass etc installed along with insulating the overhead, and tyvek installed i know it will make a good differenace.
no insulation old asbestos siding: notice there is literally no insulation at all.
new insulation plywood, tyvek and double pain glass
home made fisher stove last winter doing the job.
valves on he back are for the gasification reburn, but it works too well raises temp quickly, to high (for comfort not safety) and goes through more wood. now days only use during initial 1 hour to bring cabin from -15° to 20°c then it gets shut off. i also put a viewing window in the side for ambience purposes.
