No, because as a reliable construction technique and an insulation product, this has been disproven many times. What you are quoting is what is known as an assembly R-value, not a product R-value. IF (and that's a really big IF) you can repeatedly construct a system of two air-sealed chambers using this product, time after time after time from joist bay to joist bay, you might theoretically achieve R21 as an assembly R-value. But doing so will be extremely difficult if not impossible, which is why federal law (16 CFR 40) has a provision known as the R-value Rule. That rule states that if a manufacturer is making claims that its product is a type of insulation, then the advertised R value must be that of the product alone, and NOT an assembly value. Reflectix has been called out for this type of shenanigans before, including in a 2021 Green Building Advisor article by energy expert Martin Holladay (
https://www.greenbuildingadvisor.com/article/a-new-look-at-foil-faced-bubble-wrap).
If you actually believe the advice you are touting, you have yourself been duped. Reflectix has a product R-value of about 1.1 and should not be viewed by anyone as a replacement for a true insulation product that contributes significant R-value, period. As I noted in my previous post, I have personally used the product in situations where I wanted a RADIANT barrier/reflector, and I've even used it with proper taping as an air barrier. But in all those situations I also used a product that has a far better product R-value, as the REAL insulating product. This nonsense has been around for almost as long as bubble wrap itself. But it was nonsense then, and it's nonsense now.
