Small panels are: Easier to mount. Lightweight. Super strong.
Larger panels are a pain to mount on vehicle roofs. But if you can do it, go for it.
Also, be sure to add a safety cable in case your mounting methods fail.
Larger panels are cheaper.
I could never mount them on my rv roof's because I had vents/skylights in the way. 100w panels fit roof racks and small spaces between vents nicely.
So it depends on your roof.
That would be interesting to know MrNatural22. What kind of controller would handle charging for this? Isnt there a efficiency advantage to using 12v solar penels or does the MPPT convert it regardless?
MrNatural22, that is a nice setup.
What do you mean by safety tethers?
Also I assume thats a 40 Amp controller?
Also I am curious, would that controller work with a 10.95 V nominal battery?
Here is my battery:
6000 CYCLES LITHIUM ION POLYMER 12V BATTERY ELECTROVAYA 10.95V 80AH EV3S2P 1KWH
THIS COULD BE THE GREATEST BATTERY ON THE MARKET. RATED FOR UP TO 6,000 CYCLES, THESE ARE MADE WITH LITHIUM ION CERAMIC TECHNOLOGY. THE 2ND PHOTO SHOWS THE DATASHEET OF THE CELLS USED IN THIS MODULE. THIS MODULE IS MADE OF 6 OF THOSE CELLS IN 3S2P CONFIGURATION. ALTHOUGH THE STATED CAPACITY ON...batteryhookup.com
With no actual subtext associated, ie, we aren't going to tell you just how we get this many cycles from our product. Odds on they've done the usual and moved the goal posts to increase cycle count. Based on the number I'm guessing somewhere south of 70%. The normal measure of cycle count is when the battery has fallen to 80% of its original capacity.Up to 6000 cycles*
All things considered, it would need a very long barge pole indeed for me to get within poking distance of that battery.
I'm working on a CTC build as well. Nice to see others. ?I’m building a 6x10 cargo trailer conversion that has limited room because of a center fantastic fan on the roof. I’m using a 4215BN EPever MPPT CC.
The one 327w sunpower mono panel is basically the same dimensions of the three 100w panels mounted together, but 20lbs lighter. There would also be room on the rear portion of the roof for a second 327w panel if I
upgrade in the future. If I run them in parallel I’d have 60v @ 11.5 amps into the MPPT on a good day.
And as Will said safety tethers on the panels for peace of mind.
View attachment 1467View attachment 1468
I’m using a EPever 4215BN MPPT.That would be interesting to know MrNatural22. What kind of controller would handle charging for this? Isnt there a efficiency advantage to using 12v solar penels or does the MPPT convert it regardless?
