12VoltInstalls
life passes by too quickly to not live in freedom
I did something wrong today.
I had to weld a couple small things and was about to plug into the generator when! I thought it would be inter-cool-resting to see what happened if I tried to use the solar system.
I have a 2000W psw QZRELB/Reliable inverter currently sourcing from only two 140Ah 12V LiFePo batteries in parallel.
Welder is a Lincoln 120V spooled with fluxcore. It ‘can’ and has run on a 15A breaker but long welding trips it after a bit. 20A breaker and it will run continuously until duty cycle if not on a long extension cord.
I made my five small welds on “C” (3rd of 4 positions) and 2 wire speed. On the 2kW inverter. Surprises me that it worked! Don’t know what actual amps were unfortunately, but I might try the 120V mig next time.
Pretty cool little experiment to me. I’m quite entertained. Very pleased with myself LOL
I plan to get a QZRELB 3000W version at some point. For little fab stuff and sheet metal it appears I won’t need the generator, and the headroom of the 3000W should be sufficient if the dang welder didn’t fault out the 2kW unit. I feel so giddy and juvenile right now
