I have set up a system using a single 240W panel with two parallel connected 50Ah Lithium batteries and a PWM controller, I have short 12V LED strip lights switched in every room of the house. As winter approaches there is not enough power from the single panel so I will be adding an additional 300W panel with its own MPPT controller (the new panel will be at a different angle to my existing one) research on YouTube shows this to be an acceptable solution.
For reference - currently (October 2023) the setup is using around 15Ah per day and the panel is replacing around 7 - 14Ah per day.
My question is - This setup will not be enough to cover December/January requirements. I am considering if I can use the wall mounted Mains (240V) charger that came with the battery (there were two chargers as I bought the batteries separately) but where do I connect it into my system?
Direct to the each end of the battery "pack" (charger +ve to battery #1 +ve, charger -ve to battery #2 -ve)
Should I disconnect my solar panel feed(s) to the controller when I need to use the mains charger?
Should I disconnect the battery "pack" whilst I use the mains charger?
Thanks in advance for any help. Also is this in the correct section?
