Mirlen
I'm pondering about mounting 2 full size 400-550W panels sideways on a fence that is in front of our air conditioners. I see a lot of those cheap $25-30 mounts and some are even 41" that might fit this size panel but I suspect they aren't up to the task and would need 3-4 per that size panel if they'd even work. Any other budget options that you'd suggest? This fence is wood but has about 3-4 steel posts in the ground making it pretty sturdy, span is about 158" long which should handle 2 decent size panels.. Budget friendly easy options appreciated!
