irmscher001
I have 2 x 11 kw off grid inverters installed in parallel in UK, with 6 Pylontech US5000. These are single phase, and initially were setup without PV, and monitored using Solar Assistant. They were setup to run at 230v single phase, and were running just fine charging at night and discharging in daytime. Overall, I rate the inverters highly to date, they've been a dream in fact, no big issues at all, the system's a beast.
Having started up 4 PV strings (total 10.3Kw), I have noticed that the inverters have changed output voltage to 220v now, instead of 230v as desired.
I have tried changing various things on inverters, but whenever I change the output voltage to 230v it defaults back to 220v.
Anyone have any ideas? What is changing this back to 220v, is this a Solar Assistant setting issue or an inverter issue? I have not shut down the system, It is running in Solar/battery/Grid priority.
Anyone with a PIP Max and Solar Assistant that can help please?
