IHaveThePower
- Jun 4, 2022
- 49
Seeking wisdom: Can a renogy rover 30a mppt take an input of 24v panels and charge a 12v battery or does the string voltage need to match the battery nominal?
Pretty sure the classic 150 can charge a 12v battery from 24v array, but not sure about the rover and can't seem to find an answer
The details
I have two mppt charge controllers and I've just bought a string of new panels and I'm trying to figure out if I can to make use of them using my current gear.
Currently I have a midnite classic 150 being fed by 3 candian solar panels in series. 340w each, charging 24v 2s2p lithiums 400ah total
And another setup I have a renogy rover 30a being fed by 4 renogy 100w panels in parallel charging a 100ah lithium
I just bought 5 Longi 375w panels and am trying to decide if I should shift around my current setup to use the 5 longi with the classic 150
And shift the 3 (or 2 of 3) canadian solar to the rover.
any suggestions on how to best use these strings with what I have.
I dont might buying new equipment but wondering if I can use what I have.
The longi specs are
LR4-60HPH-375M
Pmax 375w
Vmp 34.6v
Imp 10.84a
VOC 41.1v
Lsc 11.60a
~I have 5 of these
The Canadian solar specs are
CS1H-340MS
Pmax 340w
Vmp 37.8v
Imp 9a
VOC 44.5v
Lsc 9.76a
~I have 3 of these
The classic 150 specs
150v operating
96a max current out
The rover specs
Max panel voc 90-100v
Max power pv 400w/12v 800w/24v
Charging current 30a
The details
The longi specs are
LR4-60HPH-375M
Pmax 375w
Vmp 34.6v
Imp 10.84a
VOC 41.1v
Lsc 11.60a
~I have 5 of these
CS1H-340MS
Pmax 340w
Vmp 37.8v
Imp 9a
VOC 44.5v
Lsc 9.76a
~I have 3 of these
150v operating
96a max current out
The rover specs
