280ah server rack battery price too good to be true?
Dave (Boog)
Colorado Springs
I received an instant message from an Alibaba supplier asking if I would be interested in a 51.2v 280ah server rack battery for only $950. Not sure what the shipping would cost but this seems crazy cheap?
I wouldn't bite
Strip everything away but the cells and you're looking at $60 per cell.
I doubt you could find that kind of a deal for 280ah cells
What sounds crazy cheap is likely to be crazy expensive bait.
I wouldn't bite
You can get 280Ah Battero from Gobel for $55 from China. But that does not include shipping etc
I’ve come to the same conclusion. Too good to be true. The case and hardware with BMS should be close to that price alone, without the cells. You can buy the cheapest 280ah cells for about $1300 delivered from China.
So the cheapest you should be able to build a comparable battery would be around $2200-2300
Yes, that’s definitely too good to be true.
This is the best I have found so far for the 280ah wall mount battery pack 14.33kwh (Check it out) -
$81.25/cell including delivery.
BMS, box, assembly included at no extra charge.
