B brum Solar Enthusiast Joined Feb 8, 2022 Messages 496 Jun 9, 2023 #61 Do you have a Sepols BMS? If yes - check https://diysolarforum.com/threads/seplos-can-bus-rs485-48v-200a-8s-16s-bms.20051/post-790692. If not - open a separate thread for your issues and I'll try to help.
shingsam New Member Joined Sep 20, 2022 Messages 8 Location N/A Jun 10, 2023 #62 brum said: Do you have a Sepols BMS? If yes - check https://diysolarforum.com/threads/seplos-can-bus-rs485-48v-200a-8s-16s-bms.20051/post-790692. If not - open a separate thread for your issues and I'll try to help. Click to expand... No, i dnt use seplos bms. I use battery from Hua*ei.
B brum Solar Enthusiast Joined Feb 8, 2022 Messages 496 Jun 10, 2023 #63 Well, open a thread, provide your current setup and configuration and people here will likely help. I'll also try to spot a problem in your setup. But this thread and your problem have close to nothing in common.
