Here's more data to add to the idle consumption debate on this inverter. My 6500 is only a couple weeks old and has firmware ver. 79.63, and the battery is one LifePower4. I am using the USER battery setting because with BMS comms enabled, I get a F69 error. I think this is because one cell or bank of cells is overvoltage. I am using the default settings in USER mode, as recommended by Signature support. My usage is mainly as home backup........ My idle consumption with just the battery connected is ~110W with the inverter output enabled, and 29W with it disabled (control panel and fans mostly, I guess). With just AC input, the idle consumption is 130W with the inverter output enabled, and 120W with the inverter output disabled. With both battery and AC inputs, the total idle consumption is ~140W, and disabling the inverter output doesn't have much effect. With both battery and AC connected, it hunts around a bit, which appears to be because of the float charge. Keep in mind that my AC power monitor and DC power monitor are different devices, with different resolution and probably different accuracy, but this is what I read. What concerns me is the high consumption when using it as utility backup....... Are there any settings / mode which reduces the consumption? ....... Is there a power saver mode like some inverters have where the unit can periodically check for loss of utility power and then start up in full? All my critical devices have a UPS, so I don't need instantaneous switchover. If not, could such a mode be incorporated into a future firmware release?
