Yes, all calculations completed. Our entire panel system is 33 modules, 3 arrays are 8 panel strings, the 4th array (see attached) is 9 panel string (so, this is why I'm inquiring on if my wiring config is correct)Yes. Have you calculated the string voltage? Is it low enough for the inverter after adjusting for cold?
Is the 9-panel string going to be on a different controller?Yes, all calculations completed. Our entire panel system is 33 modules, 3 arrays are 8 panel strings, the 4th array (see attached) is 9 panel string (so, this is why I'm inquiring on if my wiring config is correct)
Does an odd number of panels create an inbalance or does it matter?Wow, How did I miss that? Sorry.
Here is another layout that may avoid having to put extensions on the PV wires.
Normally I wouldn't say anything but being as this is a grid tie you need to have somebody elsedo it. A certified electrician.I also had posted this on the general forum. This grid tied Array consists of 9 panels and I want to connect them into a 1 string, In-Series
Is the attached diagram represent the correct wiring? THNX
Obviously if you're looking at stuff on the Internet to try and figure out how something needs to be wired in series you lack the practical experience to do this without blowing up yourself or someone else or catching your house on fire.
Please get some help , don't do this yourself.
There are so many things here that are wrong.
Seriously, we don't want to see you get hurt or anything
Ps this is why they now require permits and ul listed equipment. You cannot just see a picture on the internet and not understand the concept and think it'll work for you.
Well hopefully he will get someone to help him. It's ok to learn but not on a grid tie situation.Powerstroke is RIGHT ON and I made part of his post bold because it needed emphases
